problem with dashlights(fuse) due to halo lights
aiite so the other day i hooked up new headlights taht have the halo lights in them. they are wired into the corner (blinker) light, into the power and ground. as soon as i turned on the lights, the fuse blew. i replaced the 10 amp fuse with another one and it blew again. i then tried a 15, 20 and 30 amp fuse and the same thing keeps happening causing my dash lights to go out. does anyone know how to fix this?
RE: problem with dashlights(fuse) due to halo lights
check your connections sounds like you have one of the wires crossed. checkthewires with a test light to see which is pos and neg and if you have it wired correctly then the lights might have a short.
