supercharger?
supercharger?
i know its probably on here somewhere but i cant find it I plan on buying a supercharger for my 02 gt in the future but what things do i need to make sure i dont buy it twice. its stocked right now with flowmasters and i plan on adding a CAI and some long tube headers and a chip and so on but i know theres some parts that you have to make sure about so please help
RE: supercharger?
depending on what CAI and blower you go with they will most likely not be compatible. Centri blowers will replace everything past the t/b, and the KB setups replace the intake and plenum.Most CAI kits will also not fit a KB blower either.
If you get a chip/handheld (handheld ftw) you may or may not be able to reuse it, depending on how you tune the car once its FI. If your local shop or whoever you get the tune/blower from cannot tune that chip you won't be able to use it.
No matter what you do, unless its a turbo setup the LTs should not cause any problems
RE: supercharger?
If you want to up-grade to a CAI now and a KB later, I recommend the Demolet Tunible Induction CAI. It fits perfectly with the KB and will offer some gains on a NA car as well. That, and they're pretty.
RE: supercharger?
so then i cant use a cold air intake with a SC i was going to get the bbk CAI and some stage 1 cams and stage 2 clutch LT's 3.73 rear end will any of this work with a SC if not then what do i need to go with then?
RE: supercharger?
If you're going to go with a centrifugal supercharger, you will not be able to use the BBK CAI or any other CAI because the piping between the blower and TB will be replaced."If you go with KB, the BBK will fit but it is to restrictive for anything above 6 psi.
The cams, headers and clutch will be right at homeon a FI car.
RE: supercharger?
ok then what is the best supercharger out there what stages and where to find them and say i get a stage 3 or whatever should i match that with the cams and everything you know like stage 3 cams or stage 3 clutch etc...
