Can't get my car to go faster than 96 mph?
Old 06-07-2007, 11:39 PM
fiad06
fiad06's Avatar
Default RE: Can't get my car to go faster than 96 mph?
ORIGINAL: BADSEED
would a programmer help get me closer to 100?
It might make it close to like 98 or 97 , but seeing your a 5 spd it wont do much for you
fiad06 is offline
Old 06-07-2007, 11:41 PM
fiad06
fiad06's Avatar
you also have 18s which slow you down a little.....When I first started going to the track I used to stress at my bad times, but I got used to it now and I run much better..
Which would you rather sacrifice 2 mph in the 1/4 or your power top? lol
fiad06 is offline
Old 06-08-2007, 12:11 AM
1BadSonicBlue02GT
1BadSonicBlue02GT's Avatar
yes a programmer will help you alot! its a vert and its heavy so thats ur prob
1BadSonicBlue02GT is offline
Old 06-08-2007, 12:16 AM
DeltaV
DeltaV's Avatar
What altitude are you at. That has alot to do with it!
DeltaV is offline
Old 06-08-2007, 12:34 AM
CoolAid
CoolAid's Avatar
There is alot more science to this than meets the eye. Could have to do with where exactally your power is coming on and when...etc.... You beating my recent 14.47 but I went 97.xx MPH on that run and beat your 96 even though you were faster overall.
CoolAid is offline
Old 06-08-2007, 12:49 AM
99GTvert
is my username.
99GTvert's Avatar
ORIGINAL: 1BadSonicBlue02GT
Hell no. Verts are maybe 150 pounds heavier, not enough of a difference to notice jack ****.
99GTvert is offline
Old 06-08-2007, 12:55 AM
97modifiedmustangGT
97modifiedmustangGT's Avatar
Actually the verts will be about a 1/10 slower because of the weight but maybe a little less then a tenth but enought to where I would notice. Also what are you shifting at? You should shift about 5200-5300. First time at the track for me I shifted at 5800 then I shifted at 5200 and gained 2mph in my E.T
97modifiedmustangGT is offline
Old 06-08-2007, 12:59 AM
99GTvert
is my username.
99GTvert's Avatar
ORIGINAL: 97modifiedmustangGT
You will not ****ing notice in the seat of the pants or anything at all the difference. Like said before, there are too many variables that can offset that smidgen of extra weight.
Like you said though about the shifting points, its good to shift right at or just after peak power, which for a stock 2V Mod motor, slides right at 5100.
99GTvert is offline
Old 06-08-2007, 01:04 AM
97modifiedmustangGT
Yeah you are right about not feeling it in the seat of your pants. I must of misunderstood you. What I was talking about though was you realizing your slower ETon your slip.
Old 06-08-2007, 01:06 AM
99GTvert
is my username.
99GTvert's Avatar
That makes sense that the extra weight would cost a tenth, but...its just a tenth, and that can be outshadowed by other factors such as the motor's condition, amount of gas in the gas tank, tire pressures all around the car, weight of the driver, wind speed, temperature, elevation, driver's skill, etc.
99GTvert is offline
Quick Reply: Can't get my car to go faster than 96 mph?
