MAF??
RE: MAF??
Correct me if i'm wrong, but I believe it stands for mass air flow and basically it is a small sensorthat tells the engine computer how much air is going into the engine and adjusts for the proper air/fuel ratio. Getting a larger MAF would, then, tell the computer to send more fuel to the engine.
RE: MAF??
A larger maf doens't tell the computer to send more fuel.
The only reason to upgrade your MAF is if its pegging due to the amount of airflow coming in or if its causinga restriction (by size) of the airflow.
Its not nessicarry to replace the MAF unless you either build the engine (shortblock, heads, cams, intake) or go FI. Before that, you simply cannot flow enough air to peg the maf or cause it to be any sort of restriction.
RE: MAF??
ORIGINAL: 0hOneGT
So the people with basically stock motors who upgrade to larger mafs are wasting their time?
jwog666
12-27-2021 08:09 PM
stangin1996gt
09-21-2015 11:01 AM
