whining noise
Old 06-10-2007, 04:37 AM
Stang0005
Stang0005's Avatar
Default whining noise
There is this wierd whining noise coming from the pully area when my car is running. Im not sure what it is but im about the change out the bearings in the the three pullys that are not the main components.I started it for a sec without the belt on and it didnt make the noise. Any other ides what it could be?I dont think its the altinator because i replaced it about a year ago. Any help will be great. Thanks.
Stang0005 is offline
Old 06-10-2007, 09:20 AM
70 MACH I
70 MACH I's Avatar
Default RE: whining noise
Sounds like one of your idler pulley bearings are shot. Release your belt tension, remove the belt and rotate/spin all all accessories by hand. The accesory will sound rough, not smooth, when rotated. Check the waterpump, alternator, and ac clutch bearing as well. The most common culprits are the plastic Serpentine belt idler pullies though.
john
70 MACH I is offline
Old 06-10-2007, 11:09 AM
96GTMustangCT
96GTMustangCT's Avatar
just had the same prob. replaced my serpentine belt and idler pulley and bearing. sounds so much better. fixed my problem.
96GTMustangCT is offline
bjdutch2005
03-24-2017 03:38 AM
KingRando
10-02-2015 08:06 AM
KingRando
10-01-2015 11:16 AM
FivePointToTheOh
09-29-2015 12:53 PM
Quick Reply: whining noise
