Cut Steeda Springs?
RE: Cut Steeda Springs?
ORIGINAL: GT1999
well i think that my car should look something like that when i get 18s... so im guessing hes dropped about 2 inches
I hope they wont rub in the back, if you put people in the backseat [:@]
with my stock 17s on and my sportline springs... it looks the yellow stang on that website that i linked u to, but if u click on pro kit.....thats how mine looks NOW with the 17s... so when i get 18s , it should look like when u click on "sportline"
ouch... you dont cut your springs. BAD IDEA. just ruins the spring rate. if you do your car will bounce constantly
If he only drops it 2" or so it will not make his car bounce [>:]
There is nothing wrong with cutting the spring as long as you do not heat it while doing so. Use a band saw, cutoff wheel, or chop saw.
AND if he already has Steeda springs, he's not dropping it that much with his coil cut. On most cars one coil = about 2" A cut spring will increase the spring rate and make your car ride a bit stiffer, but dropping it an extra 1" by cutting a 1/2 coil, I will bet you a lot of money you will never notice the difference in the ride.
I've got the Ford C springs and the install directions actually say you can cut up to one coil from the front and rear to achieve the ride height you want.
Only if you get tires that have a larger overall diameter to go with your new wheels, but that will throw off your speedo and odo.
Wheel size has nothing to do with overall diameter of your tire.
ORIGINAL: GT1999
18's will give the illusion of a smaller gap in the wheel well, but Blue70 is right, you need to make the correct tire selection so as not to throw off your speedo and odometer.
ORIGINAL: Acer2428
I have steeda sport springs with no isolators up front with 18" wheels and that's basically the height I'm at.... I love it...
