standard manual transmission question
Old 06-14-2007, 06:54 PM
BBond007
BBond007's Avatar
Default RE: standard manual transmission question
ORIGINAL: clean97
I own a 97 GT manual. Is the standard tranny supposed to be kind of clunky. Like I can really feel the gears between shifts. Is this normal for this tranny? I know you are supposed to feel the gears a little which I may not be used to because I have driven other manuals and you do not feel anything. The car has almost 75,000 miles on it.
Mine was kind of clunky when I got it. Also you had to baby 2nd to 3rd because it tended to grind.
I installed a Tri-AX shifter which really helped because it always returns to center and seems more precise.
Anyway,
Recently the transmission started to pop out of 1st and 5th and I was able to drive it that way daily for a few months.
Finally, one day something inside must have failed because it got stuck giving me neutral and 1st as my only options.
Anyway, I had to do something, so I ordered a remanufactured T-45 from smartpartsauto .com, and they were awesome to deal with and claim to use upgraded and tougher parts.
Anyway, I filled it up with Royal Purple Synchromax and now its far less clunky. Actually, its pretty smooth shifting.
So maybe try an change the fluid and see if that helps.
BBond007 is offline
Old 06-14-2007, 06:59 PM
04BlueGT
04BlueGT's Avatar
Sounds like it may have a short-throw shifter in it. Is it clunky and sloppy (stock), or clunky and crisp (short-throw)?
04BlueGT is offline
Old 06-14-2007, 07:26 PM
clean97
clean97's Avatar
I just got a summit racing magazine and I read about the synchromax and I may go out and pick some up. My trans is stock and clunky, I read the other guys responses and it makes sense that they are clunky because the design is old and the trans I have and everybody else have is a basically a old race car tranny design. when it comes time to get new tranny I will rebuild the original to keep the numbers matching.
clean97 is offline
Old 06-15-2007, 04:24 AM
antwaan
antwaan's Avatar
I feel like more of a man shifting my 96 gt than my old grand am...haha
antwaan is offline
Pyrate Dave
09-10-2015 07:30 PM
Mustangmalo
09-06-2015 05:22 PM
Quick Reply: standard manual transmission question
