gear oil? automatic
gear oil? automatic
Im putting 3:73's in this afternoon to run a guy at the track this weekend. I wanted to know whats the best kind of rear gear oil to use witht he swap. I will probably switch them out for 4:10's or 4:30's later but i already had a new set and wanted to put them in just to see. any help would be greatly appreciated.
RE: gear oil? automatic
I know Amsoil gear lube doesn't need the friction modifier, I would assume the other high end synthetics would be the same.
The gears you bought should tell you the weight to run. My Richmonds called for 75w140.
musnicki
09-23-2015 07:11 AM
