99T45 in a 96
Old 06-15-2007, 10:10 PM
Sxynerd
Sxynerd's Avatar
Default 99T45 in a 96
Well I tried selling this thing and a few people on here jerkin my chain around too much so now that my trans is going out I am going to put it in my car.
Tech Guys Only, Please
I called THR a few months ago and they gave me a trans shop they go through and they told me it was an easy thing to do. What should I expect?? They told me to pull the tail shafts on the tranmissions and pull out the manual and Electronic speed sensors and just swap them out. Is this all there is to it? I've rebuilt about a few dozon TH400 but never one of these. What sould I expect,
Sxynerd is offline
Old 06-16-2007, 02:29 PM
Sxynerd
Sxynerd's Avatar
Default RE: 99T45 in a 96
NO one?
Sxynerd is offline
Old 06-16-2007, 02:57 PM
amoosenamedhank
amoosenamedhank's Avatar
I believe that is the only difference between the two. They should be the same other then the speed senors.
amoosenamedhank is offline
Old 06-16-2007, 03:10 PM
incubus1275
incubus1275's Avatar
Pulling the tail shaft off of a T-45 is slightly harder than TH400 auto all you have to do there is remove the snapring and a few bolts and its off. With a T-45 you have to deal with pushing the pin through the shift rod and dealing with all that shifter crap in order to pull it off. good luck. i'd suggest getting a ford manuel to help you do it right.
incubus1275 is offline
Old 06-21-2007, 11:16 AM
Sxynerd
Sxynerd's Avatar
Speed cals going to be the best way for me to go. Since I'm planning on swaping gear sometime in the future. 2 birds with one stone. Thanks eveyone.
Sxynerd is offline
