im a ricer wtf...
#25
RE: im a ricer wtf...
all the bulbs are flashing fast on the front and the back..i just switched over the left bulb to the right bulb and its only the left side that blinks fast..so i think its the fuse
#26
Check your flasher control unit too. Could have just gone bad. I would think you could get one at Auto Zone if that's the case, but not sure. Might have to get it from Ford. Can't see it being that expensive. Also...along with the blinker fluid, you might need an exhause sample too. Just hold a garbage bag over the pipe and fill it. Then take it to Midas or something and tell them to check it.
#27
In the rear we have to 3 differnt bulbs, Which ever side blinks faster, that's the side with a bad bulb. Maybe you shortened something with water. But rear bulbs are a little pain to replace, you have to take the carpet out. Hope that helped. Have someone turn the blinkers on, emergency blinkers, turn all the lights on, and press brake. Do a few tests and you'll know which one is out.
