To all the people to say 'never install gears yourself'
RE: To all the people to say 'never install gears yourself'
ORIGINAL: 72MachOne99GT
+2... I was under the impressiong that LSD, lockers, and whatever else were all the same thing....
A locker locks the wheels together when there is an amount of force applied to it and unlocks when there isnt. Its dangerous though becuase if you nail it into a turn the wheels lock up and youll go into a spin. Lockers really arent good for sports cars on the street. Lots of trucks use them and aren't as bad do to the much larger tire diameter.
A spool just permanently locks the wheels together all the time. Completely terrible on the street; youll go through tires like nothing and will have a reall hard time turning.
Edit..there are different types of lockers, some are always open some are always closed until the external force requries otherwise. It all depends how they are made. They are a pretty rough ride.
ORIGINAL: czwalga00gt
Yeah... backlash was .01 after some shim rearranging, the torque resistance was 30.5 in lbs. Which with brand new bearings the spec is from 18-29 in lbs. I left it because 1.5 in lb's is negligable, could change just from the torque wrench i was using. The ring gear pattern was pretty much perfect; a little towards the toe if anything but all contact was in the center of the gear.
I may just burn that gasket... making me drain the oil and take it off again... pisses me off haha.
ORIGINAL: contentsunderpressur
Did you measure backlash? Did you paint the ring gear and check the wear pattern? Did you make sure you had 20 in lbs of resistance on the pinion? O yea, throw the gasket away and just use silicone.
I see you know what you were doing here. I still wouldn't suggest anyone doing it without knowing and understanding backlash, pinion bearing restitance and pattern wear though. You have to be very mechanically inclined to tackle a project like this with no experience. Great job though, you must have really done your homework.
Thanks... I sorta agree. I kinda feel that if someones not intimidated by it and does the proper research and getting thetools necessarythat they can do it themselves. I'd say the only thing that is difficult for a weekend project is finding a place that will press on the pinion bearing on the weekend. The carrier bearings can be pressed on before hand since the shims are on the outside; but the pinion they are inside, so you need to measure the old gear and old shim before you can get the bearing pressed on.
I sorta lucked out one of my old friends dad has a machine shop so he was able to do it for me... but most garages were closed, so I would have been **** out of luck with no car to get to work on monday. I made sure I had a place before I started though.
ORIGINAL: jpmustanggt
How do you like those shocks?
Pain the *** to install; I dont have an impact wrench and when you're tightening the bolt it just spins. The stock ones you could hold the bottom of it atleast to prevent it from spinning.
That said I thinkthey are pretty good, you can definatly notice a difference from the different settings.. but I havent really gotten on it to really test them out because i'm breaking in the rear end. Should know in about 2 weeks.
It's a fun install isn't it? A friend of mine and I did my car in a day. I had a little girdle leak afterwards as well. Turned out to be the axle vent was rusted and plugged up. No leaks now and the 3.73 was probably the best bang for the buck so far!
I told you it wasn't that bad man, aren't you glad you did it yourself? And as said above, use some silicone gasket maker (high temp), not the gasket they give you. It is very rewarding when you tackle a project that you have never done before and it works out great. I'm glad I did my own gears as well (saved a ton of money). Congrats man.
