Differential Fluid
#21
RE: Differential Fluid
I don't see the point in deviating from the recommended weight. Ford built them, they would know better than Autozone or any of us. And I bought Mobil 1 fully synthetic, and it says directly on the bottle that friction modifier is NOT required.
#22
Well I understand but I havent been told what the exact weight of the gear fluid I should be running. And some do contain the friction modifier, autozone didnt have mobil, or royal purple, redline.
#26
I read ya.
Ok, here's the specs...
--oil--
type = motorcraft SAE 80W90 premium rear axle lubricant (GL-5)
amount = 3.75 pints (for the 8.8 in axle)
--additive friction modifier--
type = ford spec c8az-19b546-a/est-m2c118-a
amount =One 4 oz bottle
The above came out of my 99 GT 4.6L manual. I then cross checked theinfo with the Haynes manual (ford mustang 1994 thru 2003) in case you have a different year car and it's the same.
Techsent
--oil--
Techsent
KingRando
10-02-2015 08:06 AM
09-25-2015 06:42 PM
