Oil soaked spark plug
06-21-2007, 12:43 AM
The outside of the spark plug is covered in oil down to the threads.
In addition the car has a miss.
It has 79,000 miles
06-21-2007, 12:46 AM
RE: Oil soaked spark plug
Is it possible oil was accidently spilled and it went down the spark plug whole. I imagine the spark plug boot also had oil on it? which can cause a miss
06-21-2007, 01:29 AM
When I pulled the old plug out it was oil soaked,
I swapped the plugs, drove 45 minutes, pulled the plug and it was soaked.
06-21-2007, 01:30 AM
I ♥ Acer
Blow-by
06-21-2007, 01:31 AM
Check your valve cover.
06-21-2007, 01:32 AM
head gasket?
06-21-2007, 01:34 AM
just to clarify the porcelen side is getting wet with oil?
06-21-2007, 01:35 AM
Quote:
ORIGINAL: blackstallion666
Yes
06-21-2007, 01:37 AM
Valve cover is leaking.There is no other place up top that has oil run threw it.
06-21-2007, 01:49 AM
that is true check valve cover thoroughly
