how do i install cobra roters on my gt
i am getting cobra roters from my friend to put on my 98' gt. the fronts are the only difference right do they just bolt right on or do i have to buy special parts?
RE: how do i install cobra roters on my gt
You will need the pads, calipers, rotors, and you should definatly look into new lines (more the likely yours are showing wear with a 98 GT).
Other than that, its a simple install.
As it was said, you will need Cobra calipers. The pads for cobra calipers are different than the GT ones. Everything else will work with the cobra calipers + rotors, it's very straightforward. As 2000GT4.6 said, you may want to look into new brake lines, though, if you're on a budget, you don't NEED them.
on a 98 you have to replace the brake lines...they are different on 99-04's so when adding the Cobra brakes you don't have to change lines but us 96-98's do. Front that is...
ORIGINAL: 98PONYGT
11-10-2015 11:39 AM
