Maybe a big uh oh...please let me know!
I'm doing a cam swap and also changing my head gaskets on my 98 GT. I helped a buddy of mine who is a technician with most of the tear down. However, he took out the cams on his own and I just went home to help with getting the heads out. My problem occurs here...I was looking around the motor and noticed that the crankshaft hadn't been aligned to top dead center and now the cams are already out. I'm not sure if this is a big deal or not because we're reinstalling different cams so I'm not sure how we'd get them in in the exact position that the old ones were in. So my question is, when we reinstall the new cams can we just turn the motor to top dead center then and the valves and cams will realign that way or will that cause damage? Also if it can't be done like that what will I need to do? Thanks in advance for all the help!
RE: Maybe a big uh oh...please let me know!
Your supposed to take the cam followers out so you can spin the cam without it opening any valves. Then you just line up the timing marks and then reinstall the followers.
well we have the cam gears and the cams out with marks on the timing chain and the gears so we know where they line up. What exactly are the followers? We just have the chains off the gears but not off the crank yet. Thanks
That's what I was thinking too. I'm doing a ton of work to it and I'd rather just get it right the first time. Is retiming it something I can do in my driveway or will I need to take it to a shop or something? Is there a write up on how to do it, any special tools or anything? Thanks again
https://mustangforums.com/m_3081129/tm.htm
as long as your not useing comp cams you can do it this way.
ORIGINAL: oxfordgt
Good sh*t!!!!
