Help! Electrical problem 2002 GT RH Headlight
My RH headlight is not working. I replaced the bulb and was careful not to touch the bulb. I checked #4, 10 amp fuse under the steering and the fuse is good.
When I checked the fog lights (by putting the headlight switch into parking light postion and pushing the foglight switch), the RH fog light is out too.
I'm more concerned to get my headlight working. The bulb I removed looked good and the wiring on the connector to the headlight bulb looks good.
Any ideas?
Thanks
Frank
Any ideas?
Thanks
Frank
RE: Help! Electrical problem 2002 GT RH Headlight
Get a test light and see if you have power and ground at the plug for the bulb. Maybe a broken wire, headlight switch depending on how it is wired
Thanks Pro50SC. Thanks for the idea. I went back out there to check that out and it checked OK. I took some electrical contact cleaner with and sprayed the connector and now IT WORKS!!
I'm happy.
Now the fog light is still out, I'll work on that later. Don't think any fog is coming anytime soon.
Frank
I'm happy.
Frank
zanemoseley
09-06-2015 12:58 PM
