telling the difference 2v/4v
Old 01-11-2005, 12:57 AM
  #21
DeViouS
DeViouS's Avatar
Default RE: telling the difference 2v/4v
but doesnt the 03-04 have the same cobra engine that the 99-01 cobras had just s/c?
Its the same specs, 4v 4.6L so how is the 03/04 cobra engine different?
DeViouS is offline
Old 01-11-2005, 05:12 AM
  #22
sp3nis
I ♥ Acer
sp3nis's Avatar
Yes mach1's are 4v's
Displacement 4.6L (4V) (281 CID)
Number of Cylinders 8
Bore and Stroke 90.2 x 90.0 mm (3.55 x 3.54 inch)
Firing Order 1-3-7-2-6-5-4-8
Oil Pressure (HOT 1500 RPM) 138-310 kPa
Drive Belt Tension a
Combustion Chamber Volume (cc) 52.6±0.5 cm c
http://www.mach1registry.com/Specs/Specs.htm
sp3nis is offline
Old 01-11-2005, 05:20 AM
  #23
DeViouS
DeViouS's Avatar
yea but does anyone know how the 03 cobra engine is different than the 99 cobra engine. other than the s/c.
DeViouS is offline
Old 01-11-2005, 11:07 AM
  #24
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
The Mach 1 engine is completely different than a 99 Cobra motor, the Mach 1's motor was completely changed.
Dan04COBRA is offline
Old 01-11-2005, 11:13 AM
  #25
DeViouS
DeViouS's Avatar
really some these guys r sayin that the used the 99 engine for the mach 1 just to put it to use. how is the mach 1 engine different?
DeViouS is offline
Old 01-11-2005, 01:15 PM
  #26
Sidewayz6.0
Super Moderator
Sidewayz6.0's Avatar
Different Intake Manifold, They changed the heads, and I believe the cams are different also.
Sidewayz6.0 is offline
Old 01-11-2005, 01:19 PM
  #27
miglet
miglet's Avatar
well it looks like im getting a 96 fully loaded GT /w black leather interior and about 59,000 miles (96,000 KM.. found that kinda funnny)
is there a site that explains the 2v to 4v conversion for 96-98 ? (maybe that one of you guys used for reference)
miglet is offline
Old 01-11-2005, 01:39 PM
  #28
Eskine
Eskine's Avatar
my 96gt isnt that slow i pulled a 14.5 all stock with a 2.01 60'
now tell me that is slow for what it is
the only reason i think it is fast cause its got 164000 miles on trans and motor.
Eskine is offline
Old 01-11-2005, 03:04 PM
  #29
miglet
miglet's Avatar
why does your car domain site say 0-60 in 2.0? that's your 60' time
miglet is offline
Old 01-11-2005, 03:12 PM
  #30
USAMuscle
USAMuscle's Avatar
ORIGINAL: miglet
It's possible, but you'd save a lot of money and headache by staying 2v if you buy a GT. All you need to do is do the PI head and intake swap and you'll be surprising a lot of '99+ GTs. It can be done very easily for less than $1,000. You can easily make Cobra-whooping power with a 2v GT. Just takes $$$.
If you really want to though and have the time and patience to deal with a 4v swap, you'll need a complete 4v engine, Cobra brake booster, Cobra computer and Cobra wiring harness for the engine compartment, among other things I'm not thinking of. I'd also opt for a T56 transmission so you don't blow up the T45.
USAMuscle is offline
Quick Reply: telling the difference 2v/4v
