Help! Seatbelt light!
RE: Help! Seatbelt light!
What's the matter 250 too much for you? Inbred meh... my family tree has branches unlike yours that is a straight line.
I can make it more? But you are a loudmouth and a coward because you throw down and then weasel away as I stated...Tisk, Tisk [sm=loser.gif]
ORIGINAL: BuzzCut
ok then, as far as the seatbelt goes you can use the method to turn off the alarm.
I had this problem but it was due to the owner before me cutting the seatbelt wire at the buckle, so even when I had it buckled it would chime and light. Also, the seatbelt disabling trick wouldn't work because of the cut wires.
The problem was the cut wires were actually touching and completed the circuit so I simply seperated them and taped them unlike the hack who owned it before me.
