knocking sound...please help
Old 06-27-2007, 11:35 PM
siwelk
siwelk's Avatar
Default RE: knocking sound...please help
ill check out the timing cover tomorrow...im hoping it may be somethin simpler than rod knock. ive had a couple people come look it over but theyre not sure what it is. im hoping to get a mustang guy to come check it out by the end of the week.
siwelk is offline
Old 06-27-2007, 11:55 PM
ackuric
ackuric's Avatar
my knock was loud and nasty but not from inside the car w/ windows up, doors shut, hood down. i feared rod knock. within 10 seconds my mechanic with no tools diagnosed it as a timing chain slapping. got it apart noticed timing guide wear on the driver side, where the noise was heard more. replaced both guides, tensioners and the sound diminished. that also happened with a good oil leve in my case.
ackuric is offline
Old 06-28-2007, 12:00 AM
ackuric
ackuric's Avatar
that really really sounds like my stang w/ the failed tensionor. in which case professional repair would cost 6-800$
sounds more like a slap than a knock. tap tap tap tap tap tap slap slap tap slap tap slap a tap in the tappity tap
ackuric is offline
Old 06-28-2007, 12:07 AM
siwelk
siwelk's Avatar
it does seem louder on the drivers side like you say. ill definately check that out...i was thinkin it had to be a rod or bearing because of the low oil but i wasnt driving the car when it happened i just got the information relayed to me and who knows how accurate it was. thanks though.
siwelk is offline
Old 06-28-2007, 08:58 AM
SmallFeesh
SmallFeesh's Avatar
Listening to the video, it would seem like it would be a spun rod bearing, or bent rod, etc..... but since you had just started it... and I am guessing the motor was cold when you shot this video.... Im not so sure... when my Camaro spun a rod bearing it wouldnt make the noise untill AFTER the motor warmed up a bit, with the oil cold and thick, it maskes the noise, as the motor got warmed up and the oil got thinner the noise got louder.... but then if you have metal shavings in your oil like the guy said, the you have a spun rod bearing cut and dry!
SmallFeesh is offline
Old 06-28-2007, 10:02 AM
siwelk
siwelk's Avatar
yeah, that was a cold start. it sounds like that as soon as i start it up and it doesnt go away if i increase rpms...it just gets faster.
well i just found out these jokers didnt even check the oil for metal shavings like i thought. ill drain some oil and look at it this afternoon. this whole situation really pisses me off. [:@]
siwelk is offline
Old 06-28-2007, 10:19 AM
SmallFeesh
SmallFeesh's Avatar
Really.. if it were a spun rod bearing you should have some metal shavings on your dipstick!
Old 06-28-2007, 12:53 PM
siwelk
siwelk's Avatar
ive listened to a few spun bearing vids of stangs and mine doesnt sound like the ones ive heard. mine has a tapping sound that begins at startup(cold) and it doesnt go away when it warms up, it doesnt get worse or louder and it doesnt go away with higher rpms. it just gets faster. it also has a consistent interval between taps...it never skips one or has a different time interval between taps. it has a cyclic tapping sound which makes me think it may be something like ackuric was talking about.
siwelk is offline
Old 06-28-2007, 03:04 PM
ackuric
ackuric's Avatar
timing chain/tensionor failure is much more common in 4.6 engines than rod knock.
i could be wrong but i believe the tensionor failing would be 2 taps per 1 crank revolution and rod knock would be 1 knock per crank revolution?
ackuric is offline
Old 06-28-2007, 08:39 PM
stangdriver2007
stangdriver2007's Avatar
all i know is that my mom would be fixing it since she didnt ask and it was in storage
stangdriver2007 is offline
Quick Reply: knocking sound...please help
