knock sound when idling.
RE: knock sound when idling.
ORIGINAL: wildazme
well finally found what the noise was on my car i saw that my crank shaft pully was a lil loose causing it to wobble some. i tightened the center bolt and now the noise is gone.
I'll bet your wallet feels a lot better too [8D]
(ie: internal engine repairs = $$$$$$$$$$$$$$$$$$$$$$)
I had a FORD PROBE that did that and a FORD Sport Trac i think it's just ford
ORIGINAL: 99gtstang
mines does the same not as loud untill it warms up
i had a ****ty v6 camaro that had 61k on it when i bought it and it tapped like crazy...same with a blazer i had too so its not just fords
Some Chevy motors suffer from "piston slap' which is most noticeable when the motor is cold.
The Ford 4.6 has the "rattle sound" upon start up, which is intermittent and will sometimes
be aggravated by certain brands of oil filters because of drain back valve location. It doesn't harm anything though
but can be annoying.
hey guyssss, i know this is a very old thread and all but, just wonderingg.. could you post up the vid again, because it doesnt let me see it, it says its a private album, so like, instead of asking a old question i would like to hear and see if this is my problem. thank you
breaking
10-02-2015 01:27 PM
KingRando
10-02-2015 08:06 AM
