new cams COMP XEs
RE: new cams COMP XEs
ORIGINAL: JEG447
Yeah - Probably only 3 seconds or so with the fresh motor and the mystery add. Show off - Kidding. Hope to be up and running in two weeks.
jesus! interesting. also jacks - no big deal. the 2000+ stall means a 2000 rpm or higher stall converter/torque converter is recommended. it lets the trans slip a little more and the motor to rev a little higher before locking up and taking off down the track. think of it as letting out a clutch at 1500 rpms as opposed to 3000 rpms. the 3000 rpm launch is going to be a hell of alot faster so with auto trans people put in higher "stalls" to get their track times lower (60 ft/, 1/8th, and 1/4th all greatly reduced). the higher the stall though, the more power your going to need to get it to GO! also theyre fun the "flash" (pedal to the floor rev while still in drive) at ricers since the car will "stall" and rev to your TC rpm. he he he
ORIGINAL: Reed44
Cams are not worth the money. I went from 254whp/300wtq---288whp/304wtq. Put more money into a nice spray setup and a PI swap.
ORIGINAL: 2002GTAUTOVERT
if you plan on doing anything dealing with the motor, cams are worth EVERY DIME. 34 horsepower for 600 bucks?? not too bad considering a $300.00 CAI will get you 1-5hp.
ORIGINAL: Reed44
ORIGINAL: yelw02GT
just a sugestion, check out VT cams, vtengines.com, real good products for the mod motors, i have vt cams myself, i recommend to everyone
Cams are a great upgrade- not to mention you can get a set of custom grinds based on what your build is- Cams to take advantage of nitrous, of a super/turbo charger, or just an ungodly huge cam to run N/A *cough*code*cough*- the cam is the heart of the engine, and when you change the heart everything else changes.
ORIGINAL: Zanador
