Steeda UDP's
RE: Steeda UDP's
ORIGINAL: 2002GTAUTOVERT
cool, and i didnt say your A/C wont work, i said the MAX A/C setting gets degraded if its on full blast. That was my experience... degraded A/C (only on the highest setting) and every now and then a flicker of the headlights when at a light (fixed with HID's for some reason)
ORIGINAL: POISND U
I've had the on both my 02 GT and my Cobra. In bumper to bumper stop and go traffic with the A/C blowing ice cubes and the stereo blasting....
I didn't say you did. It's a common concern that a lot of people have that I addressed with my experiences. My GT did the light thing, the Cobra doesn't....
RE: Steeda UDP's
I did mine without air tools. Just use a breaker bar for the crank pulley. The water pump pulley can be done with a ratchet. As stated before, just take the alternator off and have Auto Zone switch that one over. They'll do it for free. Rent a harmonic balancer puller while you're at it, and you're set.
Mine took me about 1.5 hours to install. I've had them on for about 5 weeks, and no AC problems. dimming lights, etc.
RE: Steeda UDP's
ORIGINAL: greatjedi
RE: Steeda UDP's
Might sound like a stupid question but did you leave the belt on while loosening the pullies?
Oh, and one more thing. Do all the pullies need to be done at the same time? For instance, if I get into the install and get the water pump and alternator done but don't have time for the crank pully, can I just throw the belt on and do it later?
RE: Steeda UDP's
Take the belt off. It's very easy, just stick your 3/8 ratchet in the hole on the tensioner, loosen it, and take off the belt.
I would definitely do them all at once. give yourself a couple of hours and you should be fine.
RE: Steeda UDP's
ORIGINAL: Shelbyville
RE: Steeda UDP's
Hey. I told you it might be a stupid question. Anyway, thanks for the feedback. My concern is the crank pulley. Any chance of breaking anything? Whats the torque setting if you know it, or is it just a bunch of gorilla grips. I think I will check with my local autozone for a puller for the balancer before I start.
mungodrums
09-28-2015 10:54 PM
09-24-2015 09:18 PM
09-01-2015 08:16 PM
