Accufab TB/Plenum Results.
Old 07-02-2007, 02:15 PM
  #31
H0SS302
H0SS302's Avatar
Default RE: Accufab TB/Plenum Results.
ORIGINAL: undecided.steve
Many people have this mod and many people are happy with it.
There is no denying that.
I'm not one of them and I received a more than a few PM from people who experienced similar problems to the ones I had.
Mostly the idle hang problem, but others reported the same loss of low/midrange torque. The one thing in common, at least for the loss of torque problem seems to be that most with the problem have automatics. Also several people reported that the car got *better* a couple of weeks down the road. Others reported that they got the car tuned and it was perfect after the tune with power through out the range.
I would say if you are looking for low end pull and have an auto, save your money and get gears.
If you are looking at going FI or full bolt ons and / or intend to get a tune, go for it because it should be a good supporting mod for your other stuff.
Also several people told me that the FRPP 70mm unit solves the idle hang problem because of some kind of a hole in the blade that is correctly sized to eliminate the hang that other TB's may experience. Don't know if that's true, but I do know that Ford only makes a 70mm upgrade and not a 75 nor do they have an upgraded plenum which to me says something about Ford's take on this.
Just my 2 cents.
_+1000
the problem with modding and not getting a 75mm.. is the modding bug will bite you and you will probably end up F/I someday. seeing as how that is usually the case, the bigger tb will net gains better than a 70mm. set yourself up for success... so you dont have to work twice as hard. go 75mm.
but see, not everybody wants to superharge there car, so to buy a 75mm plenum is overkill. 99% of the manufacturers that pedal tb/plenum combos say 70m for n/a 75m for f/i and im sure they have a reason for that conclusion.
H0SS302 is offline
Old 07-02-2007, 02:28 PM
  #32
nanaki
Retired MF Moderator
the difference between the 2 will be minimal anyway (FI or not). get whatever you find the cheapest.
nanaki is offline
Gene K
10-21-2015 11:37 PM
WHT00GT
09-15-2004 04:28 PM
S_man_9
08-19-2004 08:56 AM
UT04GT
07-18-2004 12:36 AM
rtm
07-13-2004 12:54 PM
Quick Reply: Accufab TB/Plenum Results.
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
