MGW just installed
MGW just installed
I just installed my MGW shifter for the 3650 and it's awesome. I have two questions, though.
Did you guys with the 3650 use the shift stops? The instructions said I didn't need to, and when I did the car wouldn't go into second gear, so i took them out and it was fine.
Also, is it supposed to vibrate more than the stock shifter? A girl could pleasure herself on the shifter it vibrates so much. Is that normal?
RE: MGW just installed
i used the shift stops. your suppost to put it in first and screw the stop in untill it touches than take it out a 1/4 or 1/2 turn. and do the same with 2nd gear. while its parked, and go threw the gears and make sure that the stop doesnt touch the shaft it self.
mine does vib. as well. but o well i dont hold the shifter when i driver only when i shift.
set it to the 8 o'clock place she shifts so short. youll love it.
Per Tremec and George at MGW, you do not need the stops--I specifically asked George abouth this when I got mine, a copy of his response is here...
how could the trany jump out of gear when the stops dont even touch the shaft? ive had my shifer AND SHIFT STOPS in for about 10k miles now and nothing has ever happend. even at the track.
ORIGINAL: 5speedstang
09-10-2015 08:39 PM
