Spark plug tech help
What gap is suppose to be for n/a cars? and how tight do i put them in?
Any general info would be apperciated. jimbo |
RE: Spark plug tech help
Like .054 and snug...not much tighter.
ORIGINAL: koumiss45 Like .054 |
NO. tighten them to 14 ft lbs unless you want them to blow out and strip the threads.
ORIGINAL: oxfordgt NO. tighten them to 14 ft lbs unless you want them to blow out and strip the threads. And make sure that is ft lbs and NOT inch lbs!!! Easy mistake to make. Personally, I use the Morotcraft AGSF-32C plugs on my 2004 because I like copper and these ones have the longer thread count on the body. They make them in platinum as well, which is stock, but I'm an old copper fan myself :D |
well i check all the plugs and they all came out to about .030.......so how do i gap them?
Gap 'em to about .054 inches. If you're taking them out, may as well put new back in.
14 ft lbs is about just that...snug. Most individuals do not own a tourqe wrench, although they should. You gap them using a spark plug gapper....same thing you measured them with most likely.
Make sure ya use anti-seize.
not stealing the thread but what is best spart plug between these brands[*]NGK Spark Plugs,[*]Champion Spark Plugs,[*]Autolite,[*]Bosch,[*]ACDelco,[*]E3 Spark Plugs,[*]SplitFire,[*]ACCEL
