Changing stock exhaust
well i just got my SLP LM 2 catback in teh mail. and im probably putting it on sometime this week, i rememeber people saying you need to cut off a certain spot in the stock exhuast inorder for it to come off, i mean im sure ill realize where and why when im under there but curoius and any notes to help do it succesfull, but its all bolt on
RE: Changing stock exhaust
If you're going to cut it you are going to need to cut it where the pipe goes over the axel. If you don't cut it you'll have to raise the car up a lot more in order to be able to twist/turn the pipes.
Just lift the car by the frame and take the wheels off, you should have no problem getting the stock exhaust off.
The new system should have an extra joint sothat you can install it no matter if you cant get it high enough to take out the stock pipes.
well hopfully i can take it to this army base with this guy where they have lifts, so your saying if i can get it to where ew can totally like stand under it we can slide it out? without cutting it or possibly ruining it/
ORIGINAL: ColinGT
You have to angle the tailpipes almost straight downto get the rest of the pipe to clear the axles. If you dont have a lift or a really tall jack, you will hit the tailpipes on the ground before they clear the axles.
well im prayin we get the lift, that will obviously save us alot of labor n time. thanks for al the help guys. my lm2s are jus sitting in my living room waiting to be put in damn
ORIGINAL: ColinGT
I've been out before at 3am just cause i cant stand them sittin there
jpplaw
08-22-2015 09:29 PM
91StangOwner
08-20-2015 11:34 PM
