where should I run the vacuum lines to? I T'd it off at the egr valve but I don't think its pulling enough to open up the valve. Where did you guys run yours to ?
The line for the AC that goes in the fire wall on the passenger side of the car. It's easy to find because there is only one vacume line that goes in the car there.
Yes, the small red lines are vacuum lines and any of them should work. I followed the lines back towards the firewall and hooked it up there on the rubber line.
