Last edit by: IB Advertising
Browse all: Powertrain Guides
- Ford Mustang Gt 1996 to 2004: How to Stop Coolant Leak
Step by step instructions for do-it-yourself repairs
Mystery Coolant leak
I am experiancing a small coolant leak that I have been unable to trace. Here is how all has come to be:
1997 Ford mustang gt, 87800 miles, 5 speed, only mods so far (bbk air intake, flowmaster exhaust, 3.73 rear end )
1. Last week around thursday or friday I notice a slight smell of anti freeze while driving, no steam/ smoke no obvious leaking, no green pools under car. I check underhood and see nothing but kinda smell anti-freeze, I add about 2qts water to res.
2. Monday eve coolant level light comes on. I smell it but still no smoke/steam, level in res is low but still visable, temp is near the "A" in NORMAL in the dash gauge. I check underhood again, nothing spraying, nothing dripping. I fill the res. I notice some coolant on the battery tray.
3. Tuesday car stays in garage all day. After work I start car and begin lookin for any leaks, breaks pin holes, ... nothing
after driving car for a bit smell returns, not strong, but still there. My guess is a pin hole leak someware near the front.
This doesnt seem bad but its going to be near and above 100 degrees the next couple of days and im sure thats when the $%^ hits the fan.
If any one has had this before any help would be great, Happy 4th of july everyone!!!
RE: Mystery Coolant leak
I'd take a good light and check under the intake manifold(in the front).The original plastic intake has a plastic crossover tube(for the coolant) in the front..and known to crack.My 99 had a slight leak and it was the intake crossover.Puddled into the intake valley and once the level was high enough pooled out of the back of the motor through a fact. hole in the back of the block valley.
Im having the same mysterious leak. Except I have the newer aluminum crossover tube on the intake and the water pump is fine. Im pretty sure its coming out of the side of the radiator but just very slowly. Theres no puddles and this all started to happen after my cooling system froze up 2 winters ago. I just add coolant as needed no biggie......
I still have no sign of leakage, just an odor and coolant loss.
I let the car sit today, about 20 mins ago I went out started it, ran it with air on full(max ac) for a bit, I could smell it the strongest from the front, I turn ac off, and the odor is no more. I believe its because the fan turns off.
It sounds like I might have a pin hole in the radiator, looks like its time buy some jb weld, or bubble gum(jokes)
Thanks guys, Ill keep diggin and hope to solve it soon
ORIGINAL: ghstintheshell
wont a UV light make coolant glow under the light? Dark garage, blacklight, might find leak?
i dont think it will it has to have a uvadditivein itand i dont think antifreeze does but a lot of shops will do checks for you for free cuz they want the business so id stop by a shop and have them check it out
