Vortech to Paxton?
Old 07-11-2007, 12:06 AM
2000GT4.6
2000GT4.6's Avatar
Default RE: Vortech to Paxton?
ORIGINAL: 5speedstang
just go to a procharger
If you already have the I/c setup and all the trimmings, there isn't any reason to go to a procharger, he is going to need the next step AFTER the DS1C to match the T or espcially the novi.
20 PSI on a 4.6L 2v? Good luck with that.
Edit: If you have the money for a forged/billlet shortblock and all of the engine support mods that are going to be required to make anything close to 20 PSI on a 2v (heads, cams, intake, etc etc etc) why are you so worried about staying with a 6 rib setup? Obviously you can afford to go to a 8 rib and not worry about belt slip, so pulley size should not be a problem with you.
BTW, didn't we just have a forum member that was talking about making 8-10 PSI on a 3.00" pulley? That would put it as having an even worse ratio of pulley size to boost....
2000GT4.6 is offline
Old 07-11-2007, 04:36 AM
Triisomy21
Triisomy21's Avatar
I make 8 psi on my 3.5 pulley. As for my numbers sucking...I have a feeling it was heatsoaked like a **** after driving an hour and hopping right on the dyno.
Triisomy21 is offline
Old 07-11-2007, 05:00 AM
disturbed471985
disturbed471985's Avatar
Im not to sure the t-trim spins faster dont feel like looking it up but like already said the s trimwill bogg after 17# 18lbs. At 26 my currnet t-trim is holding strong up to 6800rpm the redline for car is 7400rpm but after 6800 the boom kinda goes away!
disturbed471985 is offline
Old 07-11-2007, 06:02 AM
2000GT4.6
2000GT4.6's Avatar
In any case, at 20 PSI your talking what, 700-800 WHP in a built 2v? How much power exaclty do ya need?
Its not the boost level it can achive you need to worry about anyway, this isn't a 4cyl (even if it is a small displacement V8). What you need to worry about is CFM, and the efficentcy level at xxx CFM.
Old 07-11-2007, 09:00 AM
ZW99GT
ZW99GT's Avatar
Procharger F-1 would do you some good.
ZW99GT is offline
Old 07-12-2007, 12:03 AM
SVTfan
SVTfan's Avatar
Thanks everyone. Btw...it's a built and custom intercooled 4v. Although I appreciate the commentary about all the other things I needed to push that much boost, I’ve got all that covered, and really needed to know the boost psi based on pulley size. I spoke with Paxton and got some relative comfort. I'm going with the Paxton Novi 2000 and hope to push 20 psi. My goal is 650-700 whp. Wish me luck.
SVTfan is offline
Old 07-12-2007, 04:29 AM
disturbed471985
700hp on stock 2v??? Hope your rich!!
Also what trans u plan on using for this cause that stocker want cut it by anymeans.
Old 07-12-2007, 10:43 AM
nanaki
Retired MF Moderator
nanaki's Avatar
ORIGINAL: disturbed471985
read the post right above yours. he has a built 4v
nanaki is offline
Old 07-12-2007, 05:02 PM
1BadSonicBlue02GT
1BadSonicBlue02GT's Avatar
ORIGINAL: 2000GT4.6
Yea me
I also have a 4 core intercooler with alot of piping! it'd be 11 or 12 without the cooler i imagine.
The 2000 is supposed to be good up till 26-28 psi. thats what paxton says anyhow. while a 1000 is more like 14 psi max
1BadSonicBlue02GT is offline
Granatelli Sales
03-21-2016 06:16 PM
ctgreddy
09-20-2015 08:35 PM
09-16-2015 07:53 PM
ernesto-619
09-10-2015 01:32 AM
Soldier GT
08-12-2015 03:46 PM
Quick Reply: Vortech to Paxton?
