After PI head swap...
Once I swap the heads and intake and install some 4.10 gears which I'll order shortly, I'm curious from some of you guys with experience what you would expect the '96 GT to run in the quarter. The setup will be as follows:
'96 GT vert
PI heads & intake
MAC off-road H
Flows
4.10s
Am I in the neighborhood to guesstimate 13.6-13.7 or is that too generous? I realize the best numbers will be using drag radials which I don't have yet because don't need them with a non-PI car [>:]. What do you guys think?
'96 GT vert
PI heads & intake
MAC off-road H
Flows
4.10s
RE: After PI head swap...
I would say low to mid 13's. You will be putting down a bit more power than the 99+ because your compression ratio will be about 10:1. Get some good sticky tires also. If not the gears will be no fun.
Really, low to mid 13's...I didn't think it would be that quick. I believe the HP gain for the higher compression is only about 10-15 horses but I could be wrong. That would be pretty slick though. That puts me pretty close to 12s. I'll get some DRs after I get the gears and head up to the track to find out for sure.
hey usa, you have a 5 speed, right?? i have an auto. wonder what my times will be after my pi swap. i have been searching all over for a good deal. i ran a 14.7 last fall, as i am right now.
I may pick up some PI heads/intake today... Give me a guestimate w/ these mods:
1998 Mustang GT:
PI headswap, PI intake,
Ported plenum, Mac 70mm t/b
Densecharger w/ 85mm ProM MAF,
Steeda U/D pulleys
FRPP shorty headers (ceramic)
Mac catted H-pipe. Magnaflow Catback
4.10's
Nitto 555's (275's)
Also, what would I gain by going VT stage I's on there and how hard would th einstall be w/ the heads off of the car?
1998 Mustang GT:
Steeda U/D pulleys
4.10's
Nitto 555's (275's)
ORIGINAL: 97STANG
