is my exhaust leeking?
I have 00 gt with flowmaster setup. it doesn't drive the same. i don't feel the power anymore. it doesn't accelerate like before and everytime i step on the gas i hear the SSSSSssssssssssss sound instead of that muscular sound when i first purchased the car. is my exhause leeking?
RE: is my exhaust leeking?
sounds like it to me. let it idle or have someone rev it a little and then check under your hood so you can isolate the noise. and then when you do, you will most likely find a crack there.
ORIGINAL: y2kStangGT
..check inyour tailpipe & see if someone shoved a potatoe or something in it
Check your intake from the air filter all the way back to throttle body. You can also take carbcleaner and spray around the intake. If the idle goes up, it's getting the cleaner sucked in which means you have a leak or a cracked intake.
could it be my IAC valve too? My car has been stalling because the iac is messed up.
i will replace it when i get home from work today.
Thanks guy. I just replace the IAC and the vaccum hose. I believe the sound is gone. However, the exhaust doesn't sound the same anymore.
when i first purchased the car it sounded awsome. Now it sounds like crap. I hear the engine roaring more than the exhaust. It doesn't have that echo sound.
junior04
09-28-2015 10:53 AM
09-24-2015 09:18 PM
