Aluminum Block Pros and Cons
I recently spun a main bearing in my 99 gt. I am going to rebuild from the block up. I kinda want to go with the Ford Racing Aluminum block but I am wondering if the heat dissipation is going to be the same or if Iam running the chance of my new motor running hot? I am in the process of doing my home work now and I would like to know if any of you guys have any experience with aluminum blocks and what the pros and cons?
RE: Aluminum Block Pros and Cons
with an aluminum block.. you should start the car and let it idle for 10 minutes.. so the aluminum will heat up and expand. iron blocks this isnt necessary as iron doesnt expand or contract as much as aluminum
Aluminum Block > Cast Iron
Aluminum blocks are way better than Cast Iron blocks, heat dissapation isnt controled by the material of the block. Thats what you have coolant and a radiator for. The Aluminum block is gonna save you A **** TON of weight tho...
ORIGINAL: DaMach04
