Antifreeze Spill
I've had my car for about a month now, and this is the first time this has happened. I drove from my house to work, it was probably in the low 90s outside. When I got to work antifreeze was pouring out from under my car. I popped the hood real fast and noticed that it was all coming out of the cap. Was there too much antifreeze in my radiator? The cap looked fine, not busted or anything. And does the cap pour into the overflor tank?
I've driven it since lastnight and it has not happened again. |
RE: Antifreeze Spill
I would proabably think the cap was bad, even if you can't see it.
Do the NPI cars have the sealed system, or is it one with a overflow tank and a drain to ground? If it is, you need to check the overflow hose and see if it is clogged. |
