Brand new motor! WHAT OIL?
I was told by someone that you do not ever want to start/break-in a new motor with full synethic motor oil (i.e. royal purple) becuase it will not let the ring set right? I going to be starting the car up for the first time next weekend and I wanted to know what oil to use. I went to autozone and i figured i would buy motorcraft 5W-30 oil (which is factory i think) but they only had synethic. I ask the guy about it and he said that all motorcraft is now a synethic mix. So...What oil do i need to use to ensure the proper engine break will happen on my fresh motor? and is 5W-30 the right weight?
Also, Should i use Royal purple ATF or Syncromax in the transmission?
And does anybody know the capcity of our cooling system? Royal purple says to use 1 oz of purple ice in the cooling system per quart of capcity...
Jimbo
Jimbo
RE: Brand new motor! WHAT OIL?
ORIGINAL: JimboGT01
bump.....Is full synthenic motor oil bad for brand new engine?
I say NO SYNTHETIC!!!!!
Later
ORIGINAL: JimboGT01
sounds like synthenic is not good until the motor is broken in properly.....thanks guys.
anyone have comments about the purple ice or the power steering fluid by royal purple?
ORIGINAL: oxfordgt
I cant remember how much tranny fluid. I just filled it until it started to come out of the fill hole in the side of the tranny.
The first two oil changes should be done at 1500miles and 3000miles and I would use 10w-30. From then on use 5w-30 fully synthetic every 4-6kmi depending on your driving conditions 4k being beat on and in dusty areas and 6k for highway use
