Top 5 affordable performance mods
I just recently started driving my wifes 97 Mustang GT. It is a manual, 4.6 w/single overhead cam, 75,000 miles. Other then an aftermarket catback and a K&N filter (not intake system, just filter), there does not appear to be any other performance mods.
For these 4.6 modular engines, what would be the next 4 or 5 best mods to get for performance gains. Nothing too expensive (like superchargers, etc...).
I'm thinking:
-gears
-cold air intake system
-larger throttle body
What else????
Thanks.
I'm thinking:
-gears
What else????
Thanks.
RE: Top 5 affordable performance mods
ORIGINAL: Purple_Stang
I'm thinking:
-gears
What else????
Thanks.
I'm thinking:
-gears
What else????
Thanks.
Intake
TB WITH Plenum (you will really get the gains from the plenum)
Change out the mid pipe to a h or an x the stock is restrictive and you will get more gains then the catbac gave.
A PI head swap may be a good choice too. Money wise it isn't that bad if you get a good deal on the heads.
Gears
Intake
Intake
Would you recommend certain brands for TB/plenum? Are they easy to install? I did my intake myself... no big deal... but I simply have no clue what this TB/plenum are like.
TB... what size is best if my car is stock (except K&N intake)? Does it work according to "the bigger, the better" principle or not?
Most importantly, if I am thinking of a possibility of installing a s/c later on, would I have to replace the TB/plenum again?.. (ok, I know this sounds stupid but I really don't know)
Wouldn't it be great if there was some encyclopedia, some sort of "upgrade Bible," where you could read all this stuff
Thanks!
ORIGINAL: Summit
Save up your money and do a PI swap. Bolt-on's aren't gonna be worth the $ on that car.
