replacing pulleys
RE: replacing pulleys
You will need a 3/8 ratchet or breaker bar and an extension is helpful. There is a square hole in the body of the aluminum tensioner. All you need to do is turn the whole tensioner with the ratchet in a clockwise motion (while facing the motor) and the tension on the belt should be relieved. Reverse the process to put the belt back on.
ORIGINAL: tbirdscwd
Golfsito
10-06-2015 11:02 AM
