ETA TIMES FOR 99 COBRA?
RE: ETA TIMES FOR 99 COBRA?
Here are my mods, So you think I might be able to hit high 12s on a good day with the tires kookin? I bet low 13s are easy for the mods I have now. I'm adding 295s to the 17x10s in a couple of weeks...
2000 Cobra R Hood
Front Nose & Headlights
Fikse 3-piece Racing Wheels-17 x 10-back
17 x 8- front
Suspension/Drivetrain:
Lowered Cobra Springs
Chassis engineering SubFrame connectors(weld-in)
All Poly-Urethane bushings for independent rear suspension.
4:10 Gears
Steeda Shift Cable
Steeda Clutch Quadriant
Steeda tri-ax shifter
Engine/Exhaust:
Steeda Under-drive Pulleys
K&N Air Filter
Modified Mass Airflow
Port & Polished Intake
Diablo-Motorsports Racing Chip
Mac Pro-chamber exhaust
Dyno-max mufflers
2000 Cobra R Hood
17 x 8- front
4:10 Gears
Steeda Shift Cable
Engine/Exhaust:
K&N Air Filter
Dyno-max mufflers
I believe they run about a 13.7 bone stock and with a good drive. But with those mods I don't see why you wouldn't be able to hit high 12's but for sure 13.1. But then again it comes down to you as a driver. If you're decent then definitely low 13's. Let me know what you run cuz I'm about the same with the mods that you got. But by the time I go to the track in spring I should have about 30 more hp and some suspension work done. But that's a nice list of mods.
http://www.car-stats.com/stats/search/choosemodel.aspx
this site is pretty accurate, but some drivers are worse then others, 99 cobra 14.1 and 2001 ran a 13.5 stock....
That site is wack dude. It says that a transam runs a 0-60 the same as my gt. And a 1995 cobra R runs the quarter .1 sec faster than my car?I thought those things were supposed to be race cars. or is a 99+ GT really that fast??
