Trick Flow plenum vaccuum fittings
Ok,a few days ago i ordered my Trick Flow plenum from summit,and i was looking through their plenums again (mine gets here tomorrow),and the one i ordered didn't have the vaccuum fittings pictured with it,so i called Summit and they confirmed that it doesn't come with anything,it's just the intake body by itself. So,can someone help me out here,what size fittings do i need,and is there anything besides the fittings that i'm over looking?
RE: Trick Flow plenum vaccuum fittings
In mid 2001 Ford switch to a different size vacuum tube on the plenum. Here is pick to give you an idea of what you'll need. You can pick upa barb fitting just about anywhere.
Edit, I believe they are 1/8npt to barb and you might want to pick up an IAC andEGR gasket.
The TF plenum is packaged with the hose barbs, if the one from Summit doesn't include then then they took them out of the box. I'm betting you will get it with the fittings...
jwog666
12-27-2021 08:09 PM
BeatnikFink
10-01-2015 08:00 PM
