stock injectors
RE: stock injectors
I'm looking at the Ford chart right now. The "Corn Yellow" injector is rated at 4.43 grams of fuel per 1000 pulses, and the "Heather Violet" injector is rated at the exact same flow rate.
For all intents and purposes, these are the same injector. I don't know where this 22, 23, 21 lb. stuff comes from, but it's not accurate. The two colors are because Ford changed sources or something along those lines. Part # should read (yellow) F0TE-9F593-D5B,and (pink) F0TE-9F593-D9B. Virtually, the same part number, with the second character in the suffix being changed because a different source was contracted.
09-16-2015 07:53 PM
