START UP TROUBLE! MISSFIRE BOGGING?
I've been having trouble the last couple days with the car JUST after I start it. If the car has been started in the past say....2 hours, it does fine. It's usually only when left overnight.
My wideband sensor says everything's fine at idle. I can back up, go slow where ever I need to go. When I get out on the road and get going, my wideband GOES CRAZY LEAN! and the car starts bucking/spitting/sputtering/missing/bogging down....etc......... If I clutch it, it goes back to idle perfect. So I would try it again, same thing.
It scared the hell out of me the first time. Now, all I have to do is rev the **** out of it, and everything goes back to normal. 02 sensor readings are perfect, car drives perfect, etc. WHAT COULD IT BE? Injectors clogging momentarily? Dumping fuel at startup?
RE: START UP TROUBLE! MISSFIRE BOGGING?
Bump.
Exact same problem with my car. Took it to a mechanic and was told it was running lean "because it wasn't warming up fast enough" he replaced the thermostat and added new coolant. Problem started again the very next day. My check engine light is on though. It's giving an (air fuel metering code)
I got a question for anyone, when you drive by a wall or something that throws off sound and your windows are down, when you give it gas it almost sounds like some kind of sputtering coming from the engine. I was thinkin it was just the oil filter (is dirty)or something but i dont know to much? anybody.
I also would check your fuel system... it could be injectors, fuel filter, fuel pump... your car makes alot of power and your fuel stuff may be maxed and and giving out.... just a thought.
