REAR END NOISE , PLEASE HELP DIAGNOSE
About a week ago , a sound that appears to be originating from the rear end of my car showed up. to describe it in words is hard , but the best way i can is : a moderatly high pitched chirping or cycling sound that is constantin pitch , and increases in speed or frequency as i accelerate. I put in 4.10's like4 weeks ago , but it didn't start making the noise until just recently after i got back from the track. i almost want to say its a pinion bearing , but its not grinding , just a high pitch chirp. i was researching into it and found it could be a number of things , from wheel bearings , to shock bushings. has anyone had a similar problem ? or maybe have some idea of what it is? i'm going to change my brake pads tomorrow ,even tho they have more than enough life left , and i checked my u-joints and they turn as smooth as silk. PLEASE HELP I'M LOST. [:@] my email is adam_ferguson@***.net. any help would be a life saver!
RE: REAR END NOISE , PLEASE HELP DIAGNOSE
what kind of brakes are you using??? A cheap, hard brake pad will cause alot of noises... +1 for OEM or high quality ceramic pads if it is indeed the brake pads making noise
THE NOISE THAT YOU ARE TALKING ABOUT IS CALLED A TIP IN GEAR WHINE IT IS FROM THE BACKLASH IN THE RING AND PINION BEING OFF THE ONLY THING YOU CAN DO IS REPLACE RING AND PINION OR TRY AND REPLACE THE COPPER CRUSH SLEEVE AND SET THE BACKLASH UP TO SPEC
ORIGINAL: CLIFFROD
If the backlash is off why would you have to replace the crush sleeve. The backlash is adjusted by the carrier shims not the pinion shims.
It could be the brakes, change them and if not goodluck you're probably going to have to redo the rear end to find out what the problem is. It may help to put it on jackstands and have someone spin the wheels while you listen to see where its coming from.
ya i ran 10 times in an 1/8 mile track. so 10 burnouts lol. it would be really hard to test it while on jack stands because the noise in question requires the rear end to be warmed up already and about 15 miles per hour. i'm sorry , that was information you could have used in the first post , but it was late and i was incoherent. hopefully my brake pads fix it , i bought duralast ceramic coated.
ORIGINAL: adam_ferguson
ya i just bought them for the back , i don't plan on changing my fronts yet , i'm to frugal to spend money when i don't have to , my front brakes have a ton of life left on them.
Let me know how those work out. I like ceramic but the two sets I tried (Duralast and Pep Boys brand) both squealed like ****'s. I gave up on going ceramic unless I do a complete brake upgrade and that's unecessary for this car.
