Tire Size
Old 01-20-2005, 04:11 PM
yoshis99_cobra
yoshis99_cobra's Avatar
Default RE: Tire Size
Those look like BFG's too. I got Nitto's on mine.
[IMG]local://upfiles/8126/F11F4A7A592B4D97AEBBB421F1D5A5D8.jpg[/IMG]
[IMG]local://upfiles/8126/AE9C7A9F50BE42E0B5E1419C89333B05.jpg[/IMG]
yoshis99_cobra is offline
Old 01-20-2005, 04:31 PM
DILO2001GT
I ♥ Acer
DILO2001GT's Avatar
seei always thought you could only get 315/35's. nice now i can go bigger. Where did you get them cuz' i need to order mine soon?
DILO2001GT is offline
Old 01-20-2005, 04:34 PM
yoshis99_cobra
ORIGINAL: DILO2001GT
I don't see why discount tire wouldn't be able to get them. Any tire place should. They're just special order.
Old 01-20-2005, 04:43 PM
Blue70
Blue70's Avatar
Do yourself a favor and stick with the 315/35/17 They have the same diameter as your stock tires so you won't throw off your speedo, or odo, ect. They are plenty wide, I love them
FYI 335/35/17 are about .75" taller than stock/315's
Blue70 is offline
Old 01-20-2005, 04:47 PM
TruBlu03GT
TruBlu03GT's Avatar
thanks for all the help, and those pics are bad a$$ [sm=hail.gif]
TruBlu03GT is offline
Old 01-20-2005, 05:05 PM
code3GT
Mustang Nazi
code3GT's Avatar
ORIGINAL: Blue70
I had 315's and when I got my 335's, I rechecked my speedo....no difference. And what do you mean by stock 315's? Just curious...
code3GT is offline
Old 01-20-2005, 05:08 PM
yoshis99_cobra
ORIGINAL: Blue70
Doesn't the Diabosport Predator Tuner check for that? I could have sworn I saw that when I was doing mine for the gear swap. I'll have to check it out tonight. I'll let you know unless someone else posts it here.
Old 01-20-2005, 05:12 PM
code3GT
Mustang Nazi
code3GT's Avatar
I just went and measured...The rears 335/35/17=25" tall with 13.5" foot print, the fronts 275/40/17's=24.25" tall with 10.5" foot print.
code3GT is offline
Old 01-20-2005, 05:44 PM
Blue70
Blue70's Avatar
ORIGINAL: code3GT
ORIGINAL: Blue70
not stock 315's....stock "/" 315's. they have the same height.
A 245/45/17 should be 25.681102 tall (Stock)
A 315/35/17 should be 25.681101 tall
A 335/35/17 should be 26.232283 tall
A tire is measured. Width in mm/aspect ratio/wheel diameter.
Hope I don't confuse anyone with this but..
To find how tall a tire is devide the first number by 25.4, This will give you the width of the tire in inches.
Then multiply that number by the middle number but put a decimal in front of it (the middle number 45=.45 35=.35 ect.) This is the aspect ratio of the tire (example a 245/45/17 has a sidewall that's 45% of the width which is 245mm)
Now multiply that number by 2 (you have tire above and below your wheel)
Now add your wheel size and you have tire diameter.
So...A 245/45/17 goes something like this
245 div by 25.4 = 9.6456692 (tread width in inches)
9.6456692 x .45 = 4.3405511 (sidewall height)
4.3405511 x 2 = 8.6811022 (both sidewalls together)
8.6811022 + 17 = 25.681102 (tire diameter)
Good math to know when changing wheels and tires.
Blue70 is offline
Old 01-20-2005, 05:47 PM
Blue70
Blue70's Avatar
ORIGINAL: code3GT
335 div by 25.4 = 13.19" wide.. so you are correct
You say 25" tall, but unless your tire is WAY over inflated, you have a flat spot on the bottom, and probably some tire wear.
Blue70 is offline
Quick Reply: Tire Size
