Coilovers vs Shocks/Struts and Springs
I am planning on doing mosly handling mods from now on. I have to decide whether to go coil over or with shocks/struts. I already have springs.
Which is going to give me stiffer and better handling? Will the coilovers price be worth the handling gains?
Any other input is great.
Thanks
Thanks
RE: Coilovers vs Shocks/Struts and Springs
Well I want really good handling, but I will probably only go to road racing tracks once or twice for fun. Will Shocks/struts be near coilovers at all?
What springs do you have right now? I really like my setup for what it is.. I know coilovers would give me much more versatility, but the price difference and the uses for my car were enough to deter me. The MM Full Coil Over is a bit over$1500I believe, and I think thats with bilsteins inluded but im not sure..
I have QA1 coilovers up front. I would never go back to springs. I dont even have a front swaybar anymore and I can still keep up with my buddy in his WRX STI in the turns. Coilovers are the only way to go if you are looking for handeling.
I'm doing up my own kit based on what sitnlopro99gt did.
Only I'm doing the full route with bumpsteer, new balljoints, and new offset bushings as well.
UPR front coilovers, KYB AGX struts, MMR rears, CE shocks.
I hope its all considerably cheaper than $1500.. hah.
This is my set up and cost.
COMPANY PART PRICE[/b]
STANG SUSPENSION CC PLATES 168.03
STEEDA BUMPSTEER KIT 149.95
QA1 K MEMBER 259.00
QA1 A ARMS 259.00
QA1 175LBS SPRINGS 66.00
QA1 ADJ STRUTS 400.00
QA1 COILOVER KIT 135.00
STEEDA HD LOWER C ARMS 189.00
STEEDA HD UPPER C ARMS129.00
SUMMIT RACING PU MOTOR MOUNTS 99.00
KENNY BROWN SUBFRAME CON 119.00
QA1 SPANNER WRENCH 19.00
Total cost $1991.98
I have cut springs in the rear for now but will be going with QA1 coilover set up in the rear when I get around to it.
QA1 K MEMBER 259.00
QA1 A ARMS 259.00
Total cost $1991.98
The best deal I could find on coil-overs is through maximum motorsports... for front coilovers its a little over 1k and for front and rear it goes around 2k... thats everything you need... He will try to sell you other stuff... You have to be very specific with the salesman I got.... LOL
ive got the eibach sportline springs; koni yellow struts/shocks; MM c/c, steeda bumpsteer and i'm very happy with it, with the yellows you can make it pretty damn stiff or comfortable for cruising. I'm going to start doin a little auto-x every once in a while, but tooling around on backroads and such now, ithink it will be good enough for me.
