Lowering spring help
I just go my springs in today. Eibach Sportline. When I install them will I have to buy the C/C plates? My tires are fairly new so how long would they last if I dont have the plates for like 2 weeks? And will the rears need to be adjusted.
RE: Lowering spring help
i recently got the same springs and installed them about 2 weeks ago.i love the stance but i can already see the tires starting to change and it is getting bad. i would suggest it and save yourself from buying tires more frequently than you would like.
Your camber will be relatively bad with that drop. I believe it's around 2.5" up front? Although the plates would prob be the best way to go, when I got mine aligned the shop drilled out the mounting point of the strut to getthe camberback into specs... just an idea
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
