engine almost dying
engine almost dying
well sometimes when i reverse and then put it in to drive the car will almost die. The RPM's drop real fast but after about 1-2 seconds it goes up. Then it will go back downto 800 rpms and idle there. I have a bad rear 02 sensor so do you think that is the problem.? The car has 150,000 miles on it, so keep that in mind.
thanks guys,
ashton
thanks guys,
ashton
RE: engine almost dying
actually it idles pretty rough. It doesnt shake crazy violent but it does shake... i also have a built transmission with a higher stall and better gears.. could that have anything to do with it?
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
