[UPDATE 07/25] Completed PI Swap - 2 problems left!
RE: near finish of PI Swap - HELP w/ intake manifold sensors
ORIGINAL: cliffyk
37/64" is the proper size, however as it's a tapered threada 9/16" (36/64") will work if that's all you've got on hand. It's only 0.015" smaller, just wiggle the drill around a bit after you break through...
ORIGINAL: 97tplsGT
as far as the oem stb....when i did my intake swap, my stb didnt fit, at all, had to buy a bbk stb, and that seems like it barely clears the hood
ORIGINAL: xander0561
yes the dip stick is a beast to get back in. All I did was ran it on the out side of the manifold istead of through. I had to bend it alittle, But It's impossible to put it through, withthe manifold on the head.
ORIGINAL: jEEd
you think if i got a shop to do some modification on the oem stb, that i could make it fit? its like an inch higher on the passenger side because of my intake
ORIGINAL: 97tplsGT
gah okay so now theres a "knocking" sound when i take off and my dad says i need to either run higher octane or take it to a performance shop and have them reset the ignition or somethign because its letting in the same amount of gas but taking in all the air....
any inputs?
any inputs?
ORIGINAL: 98GreenGT
Just finished my PI intake swap yesterday...instead of tapping another hole i just used a T fitting and extended the drivers side sensor to reach over that far.
KNocking sound could be a few things but not from octane. You do need a custom tune to make sure your getting the most of the heads. You need a custom fuel map in order to not use too much fuel. You could be running lean down low and rich when you hit your air/fuel table or vice-versa....
RE: [UPDATE 07/22] completed PI swap - few questions
Dude, you arent running 93? When you did the PI swap, you bumped the compression to 10.5:1! You HAVE to run premium now! Go get that octane fixed before your engine goes boom!
EDIT: What your dad mentioned can be fixed by disconnecting the battery for 20 mins- this will flash the "Ram" of the ECU, and it will relearn the proper air/fuel mixtures at certain RPM's. Should always do this when adding a new mod, it lets you get the most out of them.
