Caster/Camber - UPr vs MM
Old 07-23-2007, 09:22 AM
jmac72187
corner carver
jmac72187's Avatar
Default Caster/Camber - UPr vs MM
I am getting front coil overs and I need to pick up some Caster/Camber plates. How do they vary company to company?
I am getting either UPR or Maximum motorsports. UPR's are $170 and MM are $200. Which are going to be best? I want to get what is better not cheaper necessarily. Although cheaper does help a bit.
jmac72187 is offline
Old 07-23-2007, 10:00 AM
oxfordgt
oxfordgt's Avatar
Default RE: Caster/Camber - UPr vs MM
Just make sure you get 4 bolt ones since you are going coilover. I would go with the MM ones.
oxfordgt is offline
Old 07-23-2007, 11:11 AM
Chopper
Chopper's Avatar
Ihave the MM parts.The fit and finish is perfect.
Chopper is offline
Old 07-23-2007, 11:27 AM
H0SS302
H0SS302's Avatar
MM makes dynomite suspension parts, yes they are usualy the more pricey manufacturer but you get wat you pay for IMO
H0SS302 is offline
Old 07-23-2007, 12:08 PM
PWORLDSTANG
PWORLDSTANG's Avatar
ORIGINAL: H0SS302
+1. MM makes some of, if not the best suspension parts for our cars.
PWORLDSTANG is offline
Old 07-23-2007, 12:17 PM
PWORLDSTANG
ORIGINAL: jmac72187
BTW, I have a brand new set of C/C plates (still in box)that I'mlettinggo for cheaper than both of those.If you're interested and want more details, PM me.
Old 07-23-2007, 01:28 PM
dsg04gt
dsg04gt's Avatar
MM 4 Bolt FTMFW
dsg04gt is offline
Old 07-23-2007, 03:46 PM
bt1288
bt1288's Avatar
H.P. Motorsports FTW!
bt1288 is offline
Old 07-23-2007, 03:51 PM
JimboGT01
JimboGT01's Avatar
i got 4 bolt cc plates from MM and QA1 coil over kit in front and everthing fit perfectly....
JimboGT01 is offline
Old 07-23-2007, 03:52 PM
fiad06
fiad06's Avatar
The are the best kind...
https://mustangforums.com/m_3464024/tm.htm
fiad06 is offline
Quick Reply: Caster/Camber - UPr vs MM
