Ticking noise from Midpipe?
I installed the Mac Prochamber today and there is this very noticable/loud ticking noise whileI accelerate. My car sounds like the muffler is busted. From the clips I've heard online, the midpipe has a smooth clean sound and mine does notMaybe I installed in incorrectly?
RE: Ticking noise from Midpipe?
ORIGINAL: 03StangerGT
I only got one in the box, I would assume that I need for for each side?
Your right. I'll go put it on. One more question. How tight should the bolts be, shouldI tighten all of them till they can't go in anymore? I would assume so but I'm just checking. There is also some ratteling now, probably becauseI didn't tighten the bolts all the way down...
This is a good play by play: Enter mustang world . com
http://www.mustangworld.com/ourpics/fcar/maci1.htm
Thanks. The site helps. I'll give it a try tonight and hopefully the noise goes away. BTW one of the header screws is stubborn and it won't let me get a bolt on and I don't have the original bolt that goes there, any suggestions?
I had the same problem with my BBK x-pipe. Get new exhaust manifold studs from your nearest auto parts store and replace them; the stock manifold studs can't butt aftermarket pipes up to the header on the driver's side.
