Nitrous Pressure Gauge
Well, I'm in the process of hooking up a Nitrous Express kit with a 100 shot for the time being. I want to run a bottle pressure gauge on a steering column pod like so:
http://mustangsunlimited.com/itemdy0...p;CatKey=74-01
whats the easiest way to route the line from the trunk to the front steering column? I've never done gauges before or ventured under the carpet/dash area.....
anyone else done this?
RE: Nitrous Pressure Gauge
If its electric then you should have a sending unit that will go to a nitrous line under the hood somewhere. Most likely tap in right before your solenoid. Run it from there through the firewall then snake it up to your pod.
Make sure you use an electric gauge. Running a mechanical gauge inside the car is dangerous and illegal. Any gauge you buy should for sure hook up under the hood at the silinoids, not from the trunk.
jwog666
12-27-2021 08:09 PM
foxtrot
09-29-2015 06:32 AM
