Normal Leak??
RE: Normal Leak??
ya mine does the same thing when i run the a/c...when i get out of the car and shut the door it knocks a drop loose and sizzles on the midpipe...haha i like it...its a routine in summer in AZ...get out of car...shut door....sssssssss....walk away like a bada$$
RE: Normal Leak??
ORIGINAL: tbirdscwd
You'd be surprized at how much condesation can come off of the A/C lines especially in really hot climates. All that water has to drain somewhere, otherwise it would end up on your carpet.
RE: Normal Leak??
ORIGINAL: Gar4pt6
RE: Normal Leak??
ORIGINAL: ackuric
exhaust leak, water will find its way out before air
thats my guess, had that problem on my cat back right before the tail pipes.
RE: Normal Leak??
ORIGINAL: JimboGT01
How will water find its way out before water does??? That makes no sense to me...
ORIGINAL: ackuric
I think you meant how will water find its way out before AIR!?
Anyways, High humidity + AC = lots of condensation = lots of water coming out.
RE: Normal Leak??
ORIGINAL: 2002GTAUTOVERT
I just noticed (never noticed this before) my vehicle is leaking what appears to be water. its on the passenger side looks like right before the firewall and it IS water. Intake isnt cracked and it is clear and has no smell or color to it. Is this normal?
110% sure.
